cleaning out my garage and found a gto engine
Old 08-22-2012, 07:41 PM
totally/ta's Avatar
Default cleaning out my garage and found a gto engine
i have four pontiac engines in my garage, there is a WT,YJ,YY and a 1970 YS block out of a 1971 gto. i took the engine codes and did a little research. anyway, my question is what are they worth???
Old 11-07-2014, 04:11 PM
kribbie's Avatar
I would guess they are worth what ever you can get for them
Old 04-25-2015, 01:59 AM
cuz68's Avatar
What you have block codes, WT-66-389-67-71-400-73-455 74-76-4OO. these are the engines with that code. Your YS-65-66-389,67-76-400-78-400. The best code you have is the YY. And as posted above thay are worth what you can get, Are all these engines compleat? If you post the head numbers i can give you more info. A good 400 or 455 goes for around $300 with out the heads, Block and crank.
carid
Member Group And Special Buys
12-24-2014 09:36 AM
81 BANDIT 4 speed
2nd Generation 1970-1981
12-22-2007 03:48 AM
JimMayor007
08-28-2007 02:24 PM
gtpnewbie
12-15-2006 09:21 PM
73bird400
11-09-2006 04:35 PM
Quick Reply: cleaning out my garage and found a gto engine
