2000 Montana Fuel lines replacement help!!
Old 01-26-2011, 12:02 PM
Sylvainl's Avatar
Default 2000 Montana Fuel lines replacement help!!
Hi,
First off great forums and very helpful... kudos to everyone!!! Here's my prob... I've bought the Haynes manual and have done numerous searches on the internet.
My fuel lines are rotting by the hour, I've already patched 2 of them. I was thinking of changing the whole lines. In my manual they show nothing and have no specs for these lines... all I have is, relieve pressure, remove lines and re-install lines. I could have wrote that myself hahaha. So far the only thing I've found is a diag of the lines inside the engine compartment. The lines are leaking past the engine compartment, so what i would need is the diam of the lines, approx. length? I assume there's only 3 to replace... supply, return and evap? If anyone knows of a good manual I would purchase it.
Thank you
Old 10-23-2011, 06:30 PM
bighank's Avatar
Unhappy fuel lines on montana failing
Originally Posted by Sylvainl
Hi,
Thank you
Happened to me too. Leaked at connection with filter and gas tank under right rear. Had to remove intake manifold to get to front connectors. A real PITA. Reported to NHTSA. NO RESULTS. They even came out and took pictures. A real benefit to Montana owners.
joy50
06-30-2008 12:15 PM
revitup600
04-26-2008 07:27 PM
ibuiltmine_o1oo
10-26-2006 01:30 PM
driver 2000
10-26-2006 12:31 PM
mh1205
05-15-2006 01:15 PM
Quick Reply: 2000 Montana Fuel lines replacement help!!
