Inserting rubber caliper pin bushings in a 99 Montana
Old 04-16-2012, 07:15 AM
bighank's Avatar
Default Inserting rubber caliper pin bushings in a 99 Montana
Removed front caliper brake bolts to replace pads and discovered the rubber caliper bolt boots were deteriorated. Also noticed the cylindrical rubber caliper bolt bushings upon removing the rubber boots with press fit collars that fit tightly into the brake caliper bracket. Got a new hardware kit and replaced the deteriorated caliper bolt boots.
Then slid the new cylindrical rubber bushings on the ends of the caliper bolts. They seemed to slide over the small end of the caliper bolt OK. Now tried to slide the caliper bolts and bushings into the caliper bracket. I did clean and dry the recesses in the bracket and the caliper bolt without bushings fit easily but sloppily in to the caliper bracket. I also lubricated the inside of the caliper boots and the end of the bolt with the bushings with caliper brake grease.
The bushings refuse to go in to the caliper bracket.
What am I doing wrong. Have done dozens of disk brake jobs but have never encountered this problem. Can't remember any other brakes which had rubber bushings at the end of the caliper bolts.
The boots were press fit into the caliper bracket and can not be removed without destroying them. The caliper bolt with the rubber bushing and grease on the end fit thru the boots OK but do not want to go into the caliper bracket.
Do you have to push the bushings into the caliper bracket FIRST without being installed on the end of the caliper bolt? If so how do you do this.
I'm stymied by this one and I have the other side to work on after finishing this side.
I did remove the old boots including the metal ring that was holding them into the caliper bracket. I removed the old bushings using needle nose pliers and thoroughly cleaned out the drilled hole in the bracket with brake cleaner. I then installed the new boots which have the metal ring which press fits into the caliper bracket. I now have the old and new rubber bushings about 1 1/2 inches long and was trying to install them by sliding them over the narrow end of the caliper bolt after putting caliper grease inside the boot and on the bushing which is on the end of the caliper bolt. Should I try seating ONLY THE BUSHINGS NOT ON THE CALIPER BOLT with something like a phillips head screwdriver or maybe a thin rod which is about the same thickness as the bushings BEFORE inserting the caliper bolt? Then inserting the caliper bolt which will slightly expand the bushings as it slides into the end of the bushing? With the bushings mounted on the caliper bolt they will not push into the caliper bracket..
Old 04-16-2012, 06:12 PM
bighank's Avatar
Default Solution:
SOLUTION: I used a medium Phillips head screwdriver to push the bushing thru the boot and bottomed it in the caliper bracket. I first used a small stick to insert some caliper grease into the bracket by sticking it into the boot and pushing it all the way into the bracket. The caliper bolt was now able to go all the way into the bracket as it just partially entered the boot. Upon disassembling the second caliper i removed the old boots with a hammer and large screwdriver and punched out the retaining circular ring till it was crushed. The bushings were deteriorated and would not come out using needle nose pliers. I threaded a large self tapping coarse thread metal screw into each bushing and then pulled them out by using vise grips locked on the end of the metal screw. I cleaned out the drilled hole in the caliper bracket with brake cleaner. I will now INSERT the new BUSHINGS along with some grease BEFORE installing the press fit boots.
Post Script:
The bushings STILL did not allow the bolt to go in far enough. I pushed one caliper bolt in far enough to jam in the bushing. When I twisted it out it came out stuck halfway up the thicker part of the caliper pin. I figured that I might have too much grease in the hole and that was not allowing the bushing to bottom. I used a coffee stirrer to bottom out and removed a very small amount of grease. Reinserted the bushing and went back to my medium size phillips screw driver. There is a fine line between pushing the bushing in with the phillips screwdriver and forcing the screwdriver inside the bushing just like the caliper had done. I finally got it in far enough so that I could try the caliper pin again. The caliper pin now went in to where the threads would catch on the piston part of the caliper which is on top of the bracket. 10 minutes later and the job was done. Whoever designed this Rube Goldberg puzzle should be shot.
Two days to do what should have been a 2 or 3 hour job.
carid
Member Group And Special Buys
03-10-2015 04:34 AM
larry pierle
04-25-2011 03:30 PM
soulmusic
10-15-2010 09:22 AM
driver 2000
10-26-2006 12:31 PM
alpinestars96
05-09-2006 12:36 AM
Quick Reply: Inserting rubber caliper pin bushings in a 99 Montana
