1980 firebird engine possibilities
i recently got a 1980 firbird and the motor is locked up it has a 231 CID 2-bbl V-6 what could i put in it?
RE: 1980 firebird engine possibilities
ANything will fit. You have Buicks V-6, there were Olds engines and Ponhco engines, all used a differnt transmission pattern from Chevy. All Fcars from Pontiac had the TH350,so I would get a Pontiac motor. All you will need is the motor mounts. Ive done the same swap.
| All times are GMT -5. The time now is 07:31 AM. |
