-   -   79 T/A Electrical Problem (https://www.pontiactalk.com/forum/2nd-generation-1970-1981-55/79-t-electrical-problem-306/)
nrider Jun 20, 2006 09:49 PM
Hoping someone can help as aspiring mechanic with little experience. I took my '79 T/A out for a spin the other day. When I attempted to start the next day, I got nothing when I turned the key - no clicking of the starter, no interior lights, no electric to any part of the car. I had the battery load tested - in good shape there. I replaced the alternator - because it was suspect and only $32 for a remanufacturer one! I checked the ground - no problems there.
So, what else should I be checking? I am getting no juice to any part of the car and it happened all of a sudden! I am stumped! Could it be power to the starter? Fusable Link? Should I give up and take this to my local mechanic?
Any help would be greatly, grealy appreciated!
Attached is a pic of my nocturn blue bird.
[IMG]local://upfiles/391/E9846D4E70FC4FB093EB0657651C0F24.jpg[/IMG]
Clint S Aug 2, 2006 04:00 PM
RE: 79 T/A Electrical Problem
Bad ground. do you have a ground strap going frome frame to engine ? If not you are grounding through motor mount and that is not good enough
firebird.77 Mar 18, 2008 08:41 AM
Make sure your power wires going to the starter aren't grounded on the starter body or frame.
