Help with brakes
Old 08-01-2015, 06:42 PM
AllGasNoBrakes's Avatar
Default Help with brakes
I just changed the master cylinder, bled the brakes but my brake pedal will not hold the pressure. I can pump it up but then the pressure goes away. Any suggestions
Old 08-02-2015, 02:32 AM
cuz68's Avatar
Welcome to Pontiactalk, Did you bleed the master cylinder also?
Old 08-02-2015, 02:58 AM
Yup bench bled
Old 08-02-2015, 03:20 AM
'79 Trans Am
Old 08-04-2015, 01:29 AM
cuz68's Avatar
Wink
I have been a member on here for over 12 yrs. http://forums.maxperformanceinc.com/forums/]Go to the suspension Tech, Scroll down to the next to last Thread, Brake pedal Issue. If you join up and thay ask how you found them, Please put down cuz68. You can also do a search on the troubles that you need to fix, Or ask in the70-81 Firebird Tech. Good luck, If you need more help just ask PY or me. cuz68. If that link dont work go to General Tech on this forum under,Rear main seal. For the link.
pontiac35hp
06-18-2011 01:42 AM
95Ville
12-30-2008 01:20 PM
kgem619
03-05-2007 01:09 AM
asnake
12-17-2006 12:14 AM
kgem619
08-28-2006 03:32 AM
Quick Reply: Help with brakes
