Help with brakes
I just changed the master cylinder, bled the brakes but my brake pedal will not hold the pressure. I can pump it up but then the pressure goes away. Any suggestions
Welcome to Pontiactalk, Did you bleed the master cylinder also?
Yup bench bled
'79 Trans Am
I have been a member on here for over 12 yrs. http://forums.maxperformanceinc.com/forums/]Go to the suspension Tech, Scroll down to the next to last Thread, Brake pedal Issue. If you join up and thay ask how you found them, Please put down cuz68. You can also do a search on the troubles that you need to fix, Or ask in the70-81 Firebird Tech. Good luck, If you need more help just ask PY or me. cuz68. If that link dont work go to General Tech on this forum under,Rear main seal. For the link.
| All times are GMT -5. The time now is 10:11 AM. |
