Overheating 400ci
Old Oct 2, 2020 | 10:33 AM
  #11
ibedanno's Avatar
I'll try setting it back but don't think it will run that far retarded. The distributor came with a set of heavier springs so we'll try that to. Thanks for your input and we'll let you know if it works.
Old Oct 6, 2020 | 03:05 PM
  #12
Snoopysvet's Avatar
Any update on the overheating?
Old Oct 7, 2020 | 11:32 AM
  #13
ibedanno's Avatar
Yeah 10 deg is way to retarded started it tried turning it back and couldn't get close to 10 deg. It runs great at 24 deg vacume pluged. Haven't tried the heavier springs. I don't get it at 24 deg it idles nice strong acceleration and maintains at or below 200 deg temperature unless it's at idle or city traffic. You think going 30 over on the bore was to much. This is the first rat motor we built. 400 ci small block. I did notice that when im at a stop the trans seems to be engaging tring to take off. maybe going to a higher stall in the torque converter would help. The only other thing i can think of is a couple electric fans
Old Oct 7, 2020 | 12:17 PM
  #14
Snoopysvet's Avatar
Do you have a double roller timing chain, if so was it advanced or retarded?
What is the idle set to?
With light springs the advance could be kicking in at idle throwing everything off, definatley try the heavy springs first
A standard 1968 - 1969 Pontiac 400 timing is 9 degrees
A 1969 RAM AIR IV - which has a monster cam is 15 degrees
https://www.tpocr.com/pontiac1.html
Old Oct 7, 2020 | 02:08 PM
  #15
ibedanno's Avatar
Stock setting 1976 pontiac firebird formula 400 is 16 deg btc with vacume plugged. Yes double roller chain not sure exactly where Wayne's set it. But when i called Melling the cam manufacturer they told me to set it at 24 to 26 deg. Idle set at 650 or 700 rpm. I will definitely try the heavy springs Friday when my son comes over and let you know how it turns out. Thanks again for your input.
Old Oct 7, 2020 | 02:11 PM
  #16
ibedanno's Avatar
the 24 to 26 deg was initial timming whith vacume plugged
Old Oct 7, 2020 | 03:59 PM
  #17
Snoopysvet's Avatar
A factory 1976 Pontiac 400 had 12 degrees.
24 to 26 is way too much initial timing
What cam do you have in there?
Pontiac firebird; timing, spark plug
Old Oct 7, 2020 | 04:05 PM
  #18
ibedanno's Avatar
You shure my book said 16 btc ok I'll try 22 btc. The cam is a Melling mtp-1
Old Oct 7, 2020 | 04:14 PM
  #19
ibedanno's Avatar
Yeah just looked timming up 12 deg is for manual trans 16 deg for automatic
kzooman83
3rd Generation 1982-1992
May 8, 2010 11:49 AM
joshua.tunison
Oct 5, 2009 12:20 PM
Joern
Sep 2, 2007 12:57 PM
yankeehonda
Apr 12, 2007 03:36 AM
saltydog
Jan 15, 2007 01:21 PM
