94 Formula Start issue
I'm having a wierd problem. I was out the other day and when I tried to start the car it started for a few seconds and now all I have is a sound like a relay under the dash on the passenger side. Battery and charging is good. Fuses are good.
any ideas? |
RE: 94 Formula Start issue
Take a look at the ignition switch. I had a similar problem a few years ago. Its contacts were burnt. It is located on the steering column.Fairly easy to change and one of the few relatively low dollar parts on an F-body.
Problem Solved.
The started was bad. we put jumper cables to the starter after it was removed and it was totaly dead. Thanks |
Cool, Good Job!
| All times are GMT -5. The time now is 04:25 AM. |
