my 95 trans am wont turn over.............
I have a 95 trans am that doesn't want to turn over. the timing belt is just about to spin and then it stops. The car makes a loud "clicking" sound when you try and turn it over. Anyone out there that might know what could be causing this?
RE: my 95 trans am wont turn over.............
oh boy...well are you familure with the opti spark at all. I hope so, if not the opti spark is pretty much the distributer on the LT1's. It sounds like your opti spark has gone bad. That can take you around 6-8 hrs to replace if you have the know how and tools. How ever. It could be your ignition coil as well. I just got done replacing both the optispark and the ignitin coil in my 95 trans am.... Good luck
Thanks for the reply ike! Now all I have to do is get it fixed. |
| All times are GMT -5. The time now is 06:20 AM. |
