Stalling issues with an automatic
Old Mar 3, 2026 | 06:52 PM
Onyx Dragon's Avatar
Default Stalling issues with an automatic
Hey all. I have this problem with my T/A. It is a 2001 with an LS1. Aftermarket cam (mild), 92mm intake manifold, 92mm throttle body, volant intake, and a tune. The problem I'm having is that it will stall when lifting at the gas at high RPM in first, or right when if I let off the gas right when it shifts to second. It is worse when the heat or A/C is on. Without the heat or A/C, it will still stall at times, but it will sometimes catch itself and the RPMs will hunt. I've replaced the IAC motor and the TPS as well. Fuel pump has maybe 20k on it, if that.
Any help or advice would be greatly appreciated.
SnowMan01
Oct 19, 2025 07:15 PM
rubberman
Dec 30, 2024 11:14 AM
javisam
Nov 13, 2007 12:41 PM
dougj4525
Aug 27, 2007 11:03 AM
95GrAnDpRiXsE
Nov 3, 2006 04:15 AM
