-   -   Tensioner Pulley Remove/Install (https://www.pontiactalk.com/forum/4th-generation-1993-2002-57/tensioner-pulley-remove-install-1231/)
AzureblueZ Nov 29, 2007 08:30 AM
This past Monday the pulley on the tensioner (for the accessory system) seized up. I have a replacement pulley, but my question is - how do I get the old pulley off. The tensioner has a 15mm nut that is used to rotate the tensioner to install or remove the serpentine belt. If I turn that nut with enough force, will it come off so I may remove the pulley?
Thanks in advance for any advice!
