-   -   1989 Bonneville Engine Dying at stop (https://www.pontiactalk.com/forum/bonneville-20/1989-bonneville-engine-dying-stop-1408/)
tgriffin61 Mar 12, 2008 06:51 PM
I have 1989 Bonneville 3800 v-6,I am having a problem with engine dying at red lights,car can idle 5-10 minuets then dies.It will start right back.Ihave replaced fuel filter,plugs,plug wires,o2 sensor, and crank sensor.I have cleaned injectors also.Any help would be appreciated.
94BonnevilleSE Sep 20, 2008 02:07 PM
RE: 1989 Bonneville Engine Dying at stop
Hello ...
One suggestion, check to make sure you are getting the correct gas pressure from your fuel pump.
I have replaced 2 fuel pumps in 235,000 miles.
Best Regards,
94BonnevilleSE
