98 Suspension
Thank you in advance for any help.
I have a 98 Bonneville with 130K. I believe the struts are bad but something I have never experienced is when I hit a bump the car tries to jump to the side. I plan on replacing the struts soon but was wondering if there is anything that may be causing the lateral movement. Thanks again!!! |
RE: 98 Suspension
Hello ...,
Check ball joints ... probably bad Best Regards, 94BonnevilleSE |
RE: 98 Suspension
My 98 is making a really bad popping sound when I turn sharply or hit a bump just right. Do you think that would be the struts or the ball joints?
I would recommend getting a conversion kit from strutmasters.com this will permanently fix your suspension problems. The conversion kit converts you from air to powder coated, American made steel that is guaranteed to last the life of the car. With air you will constantly be replacing air bags and compressors. I posted the link below so you can take a look.
http://www.strutmasters.com/pontiac-...parts-s/26.htm Hopefully this will fix the problems you are having with your suspension |
98 Suspension
show me some pictures of how the suspension is set up front and back, Ill see if I can help you out.
98 Suspension
I was just wondering if a suspension setup off a DC would fit on my 97 accord. They are Koni yellows and H&R race springs that apparently fit EGs and DCs. If anyone could help me out, it would be greatly appreciated. Ive got a deal with the guy selling them fairly cheap. Thanks...
| All times are GMT -5. The time now is 07:33 AM. |
