my 1992 bonnvill is runing like crap smells like gas
my bonnevill it used to have alot of power could it be the injector it like it stalls and feel like no power when im going like 60 it sputters like it s gonna die plz help
RE: my 1992 bonnvill is runing like crap smells like gas
Hello...
If you have not checked yet. You might want to check... 1) Check fuel pressure from fuel pump. 2) the flow through your catalytic converter. If this gets clogged you will lose power, create massive heat inside the engine compartment. |
Hello coleaclak,
I have a 1994 Bonneville SE and I had issues very similar recently. The car smellled like gas and would cut out around 50+ then pick up then cut out and gutless. In my case it turned out to be an electronic control model whic on the '94 sits underneath the coil pack. (where the spark plug wires connect) Check your auto parts store, in CA. they can test it if you take it in. The mechanic wanted $450 to fix and a week. I got the part that day and only had to pay the $79 diagnostics fee. Best Regards, 94BonnevilleSE |
| All times are GMT -5. The time now is 07:25 AM. |
