Steering wheel/column loose
Hi All,
I am new to the forum. I have a 66 Catalina Convertible. About 10 years ago I swapped out the original/automatic and 389 and put in a modified 71 455 HO and converted to a 4 Spd. I was recently able to locate and install the correct 4 sp speedometer cluster and 4sp steering column. When I installed the steering column I noticed the can move the aftermarket Grant Pontiac steering wheel up/down/left/right every so slightly (about 1/16"). I tried tightening the main steering wheel nut though that did not help. It almost seems like a bearing may be worn in the column assembly. Below is a link to the steering wheel movement. Any thoughts or suggestions? https://drive.google.com/file/d/1Q0G...ew?usp=sharing Thanks! |
| All times are GMT -5. The time now is 05:48 AM. |
