-   -   Upper Intake failure (https://www.pontiactalk.com/forum/bonneville-20/upper-intake-failure-1841/)
wulfn Feb 15, 2009 09:31 PM
Sorry if this has been beat to death, but i cant find any more info on this.
I have a 1998 Bonneville with 130,000 miles that is leaking antifreeze into the engine and out the exhaust. The car will run, but alot of white smoke comes out the exhaust.
I have read where the upper intake can fail and cause antifreeze to leak into the cyclinders.
Is it possible that this will get into the engine oil as well?
If I replace the upper intake, should I go ahead and replace the lower intake gaskets at the same time the upper is off?
Thanks in advance.
cuz68 May 9, 2015 12:48 AM
What you have is a blown head gasket.:(
