1964 GTO choke tube help...
I recently bought a 1963 Grand Prix with a 1964 GTO motor installed in it.
I need some help. The heated choke coil is not hooked up and I am looking for help. I need a picture of how it is supposed to be hooked up. According to the number on the intake it looks to be an intake off of a 65 GTO 389. 977887 is the casting number I believe. It has a Carter 4 barrel carb installed. I bought some choke tubes off of EBAY for a 65 and the one to the back of the carb works but the one to the choke doesn't. Also need to know if there is something that is supposed to go into the intake or just the tube goes into the 2 small inlets? |
You are two #s off, Your intake # is 9778817.;)
| All times are GMT -5. The time now is 06:57 AM. |
