-   Classic 1964-1974 (https://www.pontiactalk.com/forum/classic-1964-1974-51/)
-   -   1964 GTO windshields metal trim. (https://www.pontiactalk.com/forum/classic-1964-1974-51/1964-gto-windshields-metal-trim-888/)
bsakennyh Jun 10, 2007 11:57 PM
Hello,
I am new to this site. Can anyone tell me how to remove the metal trim around the front and rear windows of my 1964 GTO? I must re-seal the windows and do not want to crack them. I do EVERYTHING myself!!
Kenny.... khargens1024@msn.com
cuz68 Apr 24, 2015 12:49 AM
Thay make a tool just for that, You can get one at a auto parts or Paint place Thay are around $10. Be slow and eazy with them.
WarrenWebb Dec 18, 2017 03:53 AM
The tool that cuz68 refers to is a simple hook shaped tool widely available. Using it one has to be very careful. You should insert the tool under the trim molding & very slowly turn the tool to release the clip towards the glass. It doesn't take much movement either, maybe just 1/8" or so to release the clip. What makes it a bit tricky for a novice is if you twist the tool too much the hook end can chip & ruin a perfectly good windshield. Same goes for the backglass except there if the glass is chipped it will self destruct into a thousand pieces.
