-   DIY - Do It Yourself (https://www.pontiactalk.com/forum/diy-do-yourself-10/)
-   -   1965 bonne help (https://www.pontiactalk.com/forum/diy-do-yourself-10/1965-bonne-help-1151/)
got2havit101 Oct 10, 2007 07:18 PM
1965 bonne help
Hello everyone.....I have a 1965 2dr bonneville coupe 389 tri-power, the engineturns but will not start. I prime the carbs and she will fire right up and keep running but when i turn off the bonne and try to restart her, she just turns and turns. Once again i have to prime her with a little gas and she fires right up. Does this sound like a fuel pump issue????? Your help would be greatly appreciated
mrrat1 Oct 25, 2007 01:24 PM
RE: 1965 bonne help
Hi have you found your problem yet? You can check the pump by disconnecting the fuel line at the filter and run it to a coffee can. turn the engine over and fuel should flow into the can. I had a similar deal in my GTO. The pump eccentric was broken, it is on the end of the cam & turns the fuel pumpwhen the engine is running. HTH Dave K.
