brakes and rotors on 2001 sunfire gt
So, I go to start to change my brakes and rotors when I get stuck basically at the beginning. Does anybody know whether the bolt holding on the caliper uses a torx wrench or an allen key? and what size? It almost seems as tho its a torx and is caked with so much dirt and grime that it has the appearance of an allen key. Being i cant get my head back there, the best i could do is feel around and shove some clay in there to see what shape the impression was haha. If you have any ideas i'd appreciate it!
RE: brakes and rotors on 2001 sunfire gt
Should be an allen key... but just to be 100% sure, clean it and check with the clay[8D]
if its an allen key or hex..it should be 3/8
i dont know about that, but my 96 Grand AM haynes manual says mine has a torx fitting, and when i changed the breaks, it had a torx fitting. If i remember correctly torx is newer and used on newer cars, so yours should definitly have it.
| All times are GMT -5. The time now is 10:29 AM. |
