-   DIY - Do It Yourself (https://www.pontiactalk.com/forum/diy-do-yourself-10/)
-   -   How do you fix a speaker from cutting in and out? (https://www.pontiactalk.com/forum/diy-do-yourself-10/how-do-you-fix-speaker-cutting-out-852/)
SpeakerQuestioner May 27, 2007 08:20 PM
please answer my question.
also is it the same for all speakers cutting in and out?
please and thank you.
KansasCruiser May 31, 2007 12:58 AM
RE: How do you fix a speaker from cutting in and out?
It usualy breaks down to what is causing the speaker to cut out. It is usualy one of a couple things.
1. Wiring
A. look at the connections on the speaker. if they are on solid then move on to B
B. Either follow the wire from the speaker to the amp using an Voltmeter looking for shorts or just replace the line.
2. you could have a problem in the head unit itself or in an amplifier.
A. I would try rewiring the speaker first
badbob52 Nov 25, 2007 10:43 AM
I've got a problem with a 92 Transport. Front right speaker (top of the dashboard) appears to have a loose connection problem as it cuts in and out and crackles.
Was wondering what's the easiest way to get to the wiring connection.
TIA for any help.
