-   DIY - Do It Yourself (https://www.pontiactalk.com/forum/diy-do-yourself-10/)
-   -   should i clean or replace (https://www.pontiactalk.com/forum/diy-do-yourself-10/should-i-clean-replace-1444/)
kjelie8706 Apr 13, 2008 08:21 PM
I have a 1997 Pontiac Grand AM. I want to know if it would beokay to clean and flush the a/c evaporator or should i replace it?
gnarkill1090 Aug 25, 2008 10:57 AM
RE: should i clean or replace
Replace. Chances Are Your Going To Want To Replace All The Parts In Your A/C Assembly As In The Compressor, Drier and Condenser Because None Of These Parts Actually Go Bad. What Happens Is Your A/C System Gets Particles Of Dirt In Them and It Goes Around The System Until One Part Breaks. Now, Replacing One Part Will Work For A Bit, But You Still Have Dirt In Your System and The New Replaced Part Will Soon Fail.
