Clutch pedal Problem
We have a Clutch pedal Problem, it seems that the pedal isn't disengaging the clutch. I was told that the pedal arm will stretch or bend out of shape over time. Is this true?
The clutch cylinder and slave cylinder don't seem to be leaking, but I still don't get the full travel of the clutch pedal to release the clutch. Any Ideas? thanks:( |
RE: Clutch pedal Problem
Hey Laracroft. Had two fiero's there is an updated heavier clutch pedal also the you may need to bleed the hydrulics. they sell rebuilding kits for the clutch master and slave cyl's. Dave
| All times are GMT -5. The time now is 02:58 AM. |
