Lucas Transmission Slip and other solutions
Old Jul 8, 2008 | 01:29 PM
Laynie's Avatar
Default Lucas Transmission Slip and other solutions
i have a 97 grandam GT couple 3.1 6cyl. 108 k
i just started to notice that the transmission is slipping around 30.
if you go from 0 mph and are traveling pass 30 it would slip, but if you travel like in the city and your maybe at like 29mph and just hit 30 then there is a slight delay. the engine rpm with go up but the car will stay on 30mph for maybe 2-3 seconds.
I just got it, so i might just sell it and not worry about it.
but.. people want me to at least check in to it see if the problem can be solved.
Some said a transmission flush- its a high mileage, i dont want to cause any more damage to the trans..so no
Fluid drain and put new fluid in..- both of these i dont think are necessary because my fluid is pink. and wouldnt that be sort of like flushing? and maybe a chance to mess up my high mileage transmission?
I assume no leaks because fluid says full, but thats after it sitting over night and me riding around the block and then checking it on a summer day.. should i run a little longer? or is my reading is about as accurate as it can get.
Lucas? Anyone with a GRAND AM ever tried it? successful? no? if so, how long?
as for solenoids and valves and all that how much could that cost to replace? an estimate? i know every car is different but what about an estimate?
How long can a slipping transmission last under it doesnt go in to the next gear at all? anyone?
some please respond, unfortunatley i need this car to be dependable.
jbeall
Sep 11, 2009 12:48 PM
kielu84
Dec 24, 2006 04:26 AM
313GrandPrix
Dec 11, 2006 07:00 PM
captndave
Jun 20, 2006 12:39 AM
trdriver20
Front Wheel Drive 1987-2005
May 11, 2006 08:20 AM
