water leaks in
Hello,
I've got a 92 grand am with a 3.3 l auto. Water is getting under my carpet from somewhere. Has anyone else had this problem? Thanks for your help, Fuzzy |
RE: water leaks in
are you sure its not antifreeze comming from a bad heater core, on the passanger front floor board???? its probably a seamin the cowl area under the windsheild, or wiper pods. have a buddy hold a waterhose over that area and look for the leak. than fix it with some automotive seam seal can be gotten at any parts store fix the leak on the outside, not inside
RE: water leaks in
I'm pretty sure it's not. Ireplaced the heater core last year and i'm not losin any coolant. I'll check the outside with a water hose once the weather gets better around here.
Thanks for the suggestions. |
RE: water leaks in
run water around the top of thewindsheilds and back glass too, they can leak past the urethane glue, if so you will have tro have the window remomved and resealed, the thing is most window companys wont guarrantee they wont break the glass taking them out, and you would be responsible for replacement.
| All times are GMT -5. The time now is 06:11 AM. |
