-   Front Wheel Drive 1987-2005 (https://www.pontiactalk.com/forum/front-wheel-drive-1987-2005-47/)
-   -   heated seat problem (https://www.pontiactalk.com/forum/front-wheel-drive-1987-2005-47/heated-seat-problem-146/)
trx440ex Feb 7, 2006 08:46 PM
heated seat problem
My wife's 2002 Bonneville has the heated leather seat option. This past weekend the passenger seat heater stopped working. When you push the button on the dash, it lights, then quickly goes out. I found a black box under the front of the seat that makes a relay like noise when the button is pushed and clicks off. Any suggestions on what to buy or do next without taking it to the Pontiac garage? Sure would appreciate anyones input.
Thanks.
sleder Jun 7, 2007 10:40 AM
RE: heated seat problem
Its most likley thecusion coveritself the element is built into the cover they go open circut. Gm had a repair kit for some cars witch is cheaper than replaceing the leather seat cover.
Toms94 Nov 16, 2008 08:21 AM
Any additional thought on this? I have the same issue with my 03. Do I contact my local dealer for this repair kit? Is it something that can be fixed by a non-mechanic or electrical wizard?
TIA
Blahnik Dec 7, 2008 01:57 PM
I have a 1997 bonneville sse. Both seats went out the same time. Does anyone know where the fuse is and the relay so i can check them? I dont belive both elements went out at the same time. I lost both switch lights at the same time too. These seatshave the turn on /off switch right below and in front of both seats on the bottom of both seats. Any help appreciated thanks!!!
