antifreeze leaking at times
Hi...
I have a 2000 Grand Prix GTP that is leaking antifreeze intermittently with no change in temperature. Does anyone have a suggestion as to what may be the cause? It just seems to happen whenever, wherever. No pattern to it. Mostly you can smell it on the engine, sometimes a small puddle on the ground. Most the time the overflow is still full.[:@] |
RE: antifreeze leaking at times
Well I fixed the problem. The anitfreeze was coming out of the weep hole in the water pump. I replaced the water pump and solved the problem. While I was at it I replaced the radiator cap and found the spring to be stretched out and not working properly.
HOPES THIS HELPS SOMEONE |
i havt the same problem man with my 94. ill be sure to check the weep hole. thanks allot man.
| All times are GMT -5. The time now is 06:20 AM. |
