| asnake |
Nov 7, 2006 10:20 PM |
Brakes on 2002 Grand Prix GTP
Last Friday when I left work, I noticed a noise coming from the front of my car. It sounded like a growling or like an engine reved up to a higher than normal RPM, but it only does it once you get to 30-35 MPH & when you start to come to a stop or slow down, the sound goes down as well. After this going on for about 5-10 miles, my front brakes started rubbing and then grinding real bad when I would come to a stop. I parked the car for the weekend & on Monday, I took it to a Just for Brakes & they said the 2 front rotors needed to be replaced & it needed a brake job. So, needless to say, $522.00 later when I picked the car up from them, the growling noise is still there. They said they heard it as well & that it could either be a bearing noise or a tire noise. I took it to a tire shop today where I just recently purchased new tires & had them inspect them & rotate them, and the noise is still there. Has anyone ever had this type of problem & if so, any idea of what it could be?
