-   -   Change Oil Soon Light (https://www.pontiactalk.com/forum/front-wheel-drive-1988-2008-45/change-oil-soon-light-818/)
98GP*GT May 10, 2007 10:56 PM
I have a 98 3.8L GT and the Change Oil Soon light stays on for about a minute every time I start my car. It started happening around 94k miles. I change the oil every 3k miles so I'm not sure why the light stays on.
Any ideas would be appreciated.
Thanks,
-Nick-
jerryh20 May 11, 2007 05:00 AM
RE: Change Oil Soon Light
;)did you reset the light? with the ignition on but engine not running pump the gas 3 time and it should say light reset. good luck
98GP*GT May 13, 2007 10:38 PM
Well that seemed to do the trick. Thanks.
sumthin_serous Jun 14, 2007 08:03 AM
u might want to check your oil pan gasket. i have the same problem in my 97 GT and a mechanic said there is a leak in the pan and it causes engine oil pressure to be waaaaaaaay off when u start the car but after a few seconds the engine will build up the necessary amount of pressure and the light will go off. which is what mines does. hope this helps.
vipercarcom Dec 28, 2012 08:12 AM
Change Oil Soon Light Pontiac
I faound a site where you can find how to reset change oil soon light for all Pontiac models. http://resetservicelight.com/categor...light-pontiac/
The full procedure how to reset oil warning light for Pontiac is taken from owners manual
