-   -   Engine makes whinning noise (https://www.pontiactalk.com/forum/front-wheel-drive-1988-2008-45/engine-makes-whinning-noise-1068/)
geertsm Sep 5, 2007 02:15 PM
Hey all, I have a 1997 GTP with 216,000 miles. I just bought a 1998 GT hoping for the same result. However, the A/C unit makes a whinning noise as the belt goes over the pulley, only when the A/C is off. Can I fix this by replacing the A/C clutch only or do I have to replace the whole assembly? The guy I bought it form said he just replaced the belt. Is it possible that the belt is just too tight?
metro7100 Sep 18, 2007 01:42 PM
RE: Engine makes whinning noise
I would check the belt first. Then would look atthe tensioner pulley, these are suposed to be replace with the belt.
Most companies wont just sell you the clutch for the A/C anymore and you will probably have to buy a whole new compressor, and evaporator, then recharge you A/C system.
Phil_GTP Sep 26, 2007 09:40 PM
i would most likeley say its the clutch. i had the same problem with my 94 olds cutlass, and the clutch fixed the noise.! hope this is helpfull!
