FOG LIGHT ISSUES
ok, my fog lights arent working. i figured the bulbs were bad so I replaced them and still the fogs still dont work.
any way i can trouble shoot to find out what the problem is or am I stuck with 2 non workin fog lights? thanks |
RE: FOG LIGHT ISSUES
[&o]you should check the bulb sockets with a test light or meter and follow the wires to the connections - also be sure they are grounded - good luck
first thing to check is the fuse, the check the wiring. You could replace your stock foglights with some nice aftermarket blazertechs.
It can be the a lot like the impedance of the wires and the grounding of the fog lights! You need to make sure that the wire has sufficient resistivity to make the current flow.
| All times are GMT -5. The time now is 05:59 AM. |
