-   -   HUD display (https://www.pontiactalk.com/forum/front-wheel-drive-1988-2008-45/hud-display-52/)
nj85z28 Aug 27, 2005 10:46 AM
HUD display
sometimes my Head Up Display gets kind of dim even though i dont touch the dimmer. anyone know if it could be the dimmer itself or maybe something else> loose connection? anyone
Patrick Aug 29, 2005 03:34 PM
RE: HUD display
does it flicker, or just stay dim?
nj85z28 Aug 29, 2005 06:57 PM
RE: HUD display
it stays dim for a little bit then gets bright again. sometimes it stays fine for weeks and then once in a while it gets so dim i cant even see it
Patrick Aug 30, 2005 03:21 PM
RE: HUD display
it sounds like a loose wire..or some electrical issue
joshlarsen Jan 13, 2006 02:24 PM
RE: HUD display
I have the same issues with my HUD on my 99. It is dark most of the time now and you can only see it every once in a while even in the dark. I never touch the dimmer switch but it gets dim and bright all on its own. GM has replaced the dimmer switch and that did not resolve the issues. does any one have any other ideas?
nj85z28 Jan 14, 2006 02:14 AM
RE: HUD display
no i still couldnt figure mine out.....weird
gititdone Jun 25, 2006 11:30 PM
RE: HUD display
Strange but true I have been having the same problem with my HUD except now it rarely turn on. Sure is nice when it does work. Any suggestions would surely be appreciated.
GrindingNemo Nov 7, 2006 06:37 PM
RE: HUD display
I too have the same issue with the HUD. The dash display showing fuel range/oil life also fades in and out/resets too. I'm thinking new alternator? I've already replaced the leaky battery that was installed when i bought the car.
nj85z28 Dec 4, 2006 01:28 AM
RE: HUD display
its actually a "cold solder" problem. there is a fix for it, which involves taking the unit out and correcting the solder joints. i helped fix one a few months ago
