Can I use 15X7 rally II rims on a 65 GTO?
Was wondering if anyone is running 15x7 rims on a 65 GTO with a stock suspension? Will I have clearance problems?
My GTO has factory rims with spinner hub caps but I'd like to dress up the car and make it look a little sportier. The late model 15x7 rims rally II rims are more readily available and cheaper. I don't want to damage the car being cheap but spending $900 on repo rally I rims is a lot of $$$. |
RE: Can I use 15X7 rally II rims on a 65 GTO?
shouldnt be a problem, measure your wheel studs from the center of one to the edge of the one straight across if its 4and 3/4 you should be fine
| All times are GMT -5. The time now is 07:16 AM. |
