96 grand prix stalls
Old 06-04-2007, 05:58 AM
pup55's Avatar
Default 96 grand prix stalls
I have a 96 grand prix that keeps stalling on me. In park the engine rpms will go up and down and then just stall. Also when your on the road and let up on the gas the engine will stall. It starts fine and runs fine but keeps on stalling. This just started and could use some help. If you keep the rpms up it will not stall.
Old 06-06-2007, 12:59 PM
horse_Gal_jen's Avatar
Default RE: 96 grand prix stalls
sounds like the fuel pump.
when you start it have someone smack the underside of the fuel tank, it will bump the pump and get it working again, if it idles ok then, then I would suggest its the fuel pump.
Old 06-11-2007, 11:39 PM
jonah08's Avatar
there are several possible causes why car stalls. here are some things that you might want to check: fuel pump as well as the gmc fuel tank; bad oxygen sensor; fuel filters; low transmission fluid; weak spark. by the way, when was the last tune-up and oil change?
shaena
01-25-2009 09:00 AM
gilligans_off
08-27-2007 10:55 AM
Bracer11
05-21-2007 05:17 AM
micali
03-06-2007 08:33 PM
davc774
04-21-2006 11:21 AM
Quick Reply: 96 grand prix stalls
