1994 Trans Sport
I have a 1994 Pontiac Transport, and the bulb behind the Climate Control System (where the A/C, Recirc, Upper, B-Level, Def, Lower, Mix, Def buttons are) the bulb must have burnt out. Anyone give me instructions, or tell me where I can find the instructions, to replace this bulb?
Thanks Paul |
RE: 1994 Trans Sport
well first you wold have to remove the unit. it should be only a few screws, and then remove the bad bulb and find the right replacement
it should be fairly easy, and cheap.
| All times are GMT -5. The time now is 01:17 AM. |
