2000 gtp hard to start in the morning
this became an issue when the air was a lot cooler in the morning. When i start my car it idles for a second and stalls, and it does that for a few minutes. i have to slam the trottle to try to get it to run which is not good for it. The car runs after i see the security light comes on and then goes off. i thought it might be the crank position sensor but the car does not throw a code. could it possibly be the fuel pump. I am out of ideas and its starting to bug the crap out of me.
RE: 2000 gtp hard to start in the morning
thats very odd IMO...i have a 2001 GTP and didnt get that issue....hopefully someone knows in case it happens to me too!
how old is the battery, and the alt?
im not sure i will have to check that. I bought the car at the end of august and it had 52000 on it.
thanks |
if you go to any shop, they should have a "load tester"...that should tell you whats wrong
the battery and alt tested ok
the battery tested "ok", or good? my battery was fine until winter came..and it failed me. [:@]
| All times are GMT -5. The time now is 10:06 AM. |
