-   -   86 Firefly (https://www.pontiactalk.com/forum/general-tech-11/86-firefly-740/)
Kyle_1989 Mar 28, 2007 08:56 PM
86 Firefly
Hey I have an 86 Firefly... I'm having a bog down problem and have no idea what it could be... seems to be only when it gets warm out that it does it.
Aanyways I have gone and replaced the fuel filter air filter ran methyl hydrate through the gas tank and used some carb cleaner to clean out the carb... I dunno if I'm going in the worng direction or not
Can someone please point me in some sort of direction
I don't really wanna spend a heck of a lot of money getting a mechanic to do the fix on the car... I bought it for a hundred bucks it runs great other then this bog down problem. and with summer fast approaching i need to find a fix... please help
jerryh20 Mar 28, 2007 09:56 PM
RE: 86 Firefly
:)try carb kit - may be bad excellerator pump which comes in the kit - could be fuel pump or vacuum advance on distributor - good luck
Kyle_1989 Mar 29, 2007 09:44 PM
RE: 86 Firefly
Update on Bog down problem
I decided to take the air filter and housiong for air filter off and looked at the carb a bit it seems that just before it starts to bog i get a hesitation in the gas flow that i see coming into the carburater this might have something to do with the problem.
Thanks for the reply jerryh20 you made me come so much closer to discover the problem... I will definitely report back when I have found the fix or if I need any more assistance... again thx for your swift reply jerry
