Car Wont turn over all i get is clicking sound
Hey my names Steve i just purchased a 96 Grand prix SE, one of the bulbs was out in my speeDometer so i went to go change it and in the process of trying to take out the gauge cluster i was unable to disconnect the wireharness from the bottom of it, then when i went to start the car wouldnt turn over, all i get is a clicking sound like the starter wont ignite the engine.... any help would be great to wer ei should start checking ... THANKS!
RE: Car Wont turn over all i get is clicking sound
If you dont have one go pick up a Haynes Repair Manual for your car. Trust me they are a help.
In my Haynes repair manual for 95-01 sunfires possible problems could be: 1. battery terminal connections faulty 2. battery faulty 3. gear not in park 4. broken, loose or disconnected wiring in the starting circuit 5. starter motor pinion jammed in flywheel ring gear 6. starter solenoid faulty 7. starter motor faulty 8. ignition switch faulty 9. Starter pinion or flywheel teeth worn or broken 10. Defective fusible link |
| All times are GMT -5. The time now is 02:36 AM. |
