-   -   fuel pump issues (https://www.pontiactalk.com/forum/general-tech-11/fuel-pump-issues-7230/)
bgable Mar 28, 2010 05:58 PM
fuel pump issues
I have a 95 Firehawk that after a process of elimination I believe the fuel pump has gone bad. Is there any way to change the pump without having to drop the fuel tank? Also, if I will have to drop the fuel tank what will have to be removed in order to get it out? Thanks
nj85z28 Mar 29, 2010 05:03 PM
the only way to do that is to cut a hole in the trunk to gain access. ive seen a photo with the measurements that i will try to find for you.
