Help with removing CD Player
A while ago I lost the ability to listen to the radio in my 1999 Grand Am SE. When I asked around about it I heard i needed to remove the CD Player and disconnect then reconnect the antenna line to the back. Although now I can't figure out how to pull it out. I don't want to break anything so can anybody help me?
RE: Help with removing CD Player
remove the trim from around the radio and you will see how the radio is mounted..most likely you will need to remove a couple of nuts or bolts to remove it from the mounting area.
| All times are GMT -5. The time now is 09:43 AM. |
