-   -   timing chain cover (https://www.pontiactalk.com/forum/general-tech-11/timing-chain-cover-1343/)
smj617 Jan 28, 2008 08:35 PM
timing chain cover
I have a 1968 400 with the older style timing chaincover with the 8 bolt water pump. If I switch to the later style timing chaincover with the 11 bolt water pump, will my bracket, pully and ect. all line up and work?
________
BMW R25
72blackbird Jan 31, 2008 09:27 AM
RE: timing chain cover
Do you have a picture? To be honest I've only used the 11-bolt style. It may not work if you have brackets that use the water pump bolts to bolt to the engine.
Geno
