Using Oil
Old Jul 28, 2007 | 11:04 AM
dstrombe's Avatar
Default Using Oil
2001 Pontiac Aztek. 53,000 miles. Car is driven about 8500 miles per year. Car is using oil. No leaks on the ground. Go to Jiffy Lube, get oil changed, 1 1/2 months later the "low oil level" light comes on. Check oil and sure enough, nothing on the dipstick. In the "old days" the obvious answer is rings, but with these modern, computerized cars, was just hoping it might be something else. 53,000 miles and needing a rebuild just doesn't seem right. The last oil change, I used "high mileage vehicle" oil. No change. Any suggestions? OBDII says nothing wrong. - Thanks
Old Jul 29, 2007 | 03:53 PM
TrappedDarkness's Avatar
Default RE: Using Oil
theres no noticable leaks? maybe something leaking onto exhause manny and getting burned. If not check to color of the exhaust. If it has a blue color to it that means its burning oil. and theres a few things it could be
Old Aug 26, 2007 | 02:06 PM
vic's Avatar
vic
Reply Deleted
EvansBlue
Mar 18, 2010 02:00 PM
vic
Sep 23, 2007 11:59 PM
96RAMAIR
Mar 30, 2006 12:48 PM
diypont
Feb 8, 2006 04:49 PM
nj85z28
Jul 31, 2005 11:40 PM
