Faulty window operation
Hello all:
~I've got a driver's side window that operates intermittently. Sometimes the switch works and window is able to go up or down, and other times the switch acts like it is dead. When not working, the switch doesn't even activate the motor - i.e. no humming (like a stuck motor...) Both passenger window switches work. Just the driver's window switch is bad. Could this be the switch panel? a loose fuse? wire? Car details: 2001 Grand Am GT 6cyl. Thanks for any advice- Jc Abry |
Had the same problem with my car too, I had check some switches replaced them and works fine later.
__________________________________________________ _______________________________ Brake Caliper/Brake Light Switch/Window Switch Panel/Brake Switch/Bumper Cover |
Free Fast Shipping http://www.switchdoctor.net 30 day return Policy
| All times are GMT -5. The time now is 06:59 AM. |
