-   -   grand am 1999 (https://www.pontiactalk.com/forum/grand-am-18/grand-am-1999-a-237/)
vikicar67 May 13, 2006 11:52 AM
grand am 1999
My grandam has been running sluggish and the check engine light is on. I have replaced the spark plugs and wires and also the ignition coils. the light is still on and it still has a bad take off. the vehicle seems to burning more fuel. it has been hooked up the machine and they can seem to figure it out.
Jeremy@fredbeans Sep 15, 2006 02:53 PM
RE: grand am 1999
If the light is then there should be a code stored. Possibly a Converter issue.
flashy grand am Jan 10, 2007 07:53 PM
RE: grand am 1999
have you reset the computer (key in ON position, push gas petal to the floor 3 times normal force don't slam it) reset it and if the light comes back on than you should be able to check it with the machine
GrandAMGT4 Mar 4, 2007 12:57 AM
RE: grand am 1999
a lot of time itsa computer issue
grandamkid Mar 9, 2007 05:01 AM
RE: grand am 1999
[align=left]Have the codes pulled so you can diagnose the problem.It also could be your o2 sensor if you are burning more gas it could also be a transmition problem.My car did the same thing.Does you check engine light come on when you reach a certain speed?
[/align]
