Idle Drops Then Returns While Driving Only When At Operating Temperature
I have a 1999 Olds Alero with the 3400SFI V6 about 173k on Engine (up until rebuild) and 65k on transmission.
So a while back I fitted a Pacesetter Cat-Back exhaust to my car, about a month later the RPMs would drop to idle then come back up (while driving at operating temperature) then a week later it progressed to the RPMs sticking at 3000 once that RPM was reached and refusing to accelerate further. Then about a week later, the engine gave up the ghost, the rear center piston looked as if it exploded, the head was ruined too (valve was pushed in and holes in surface of head). I went and got two new heads, and all new pistons and wrist pins, and rebuilt the motor. I retained the old belt drive components, the old timing components, oil pump, rods and bearings, crank and bearings, cam and bearings, injectors, intake components, and exhaust piping. New parts were pistons and wrist pins, used heads, valve stem seals, head gaskets, intake manifold gaskets (upper and lower), fuel injector seals, exhaust manifold seals, spark plugs, 7x crankshaft sensor, thermostat and gasket, throttle body gasket, and oil pan gasket (maybe forgetting some things). About two weeks ago now, the car began dropping RPMs to idle and then back. But only when in motion and at operating temperature. I haven't driven it since it began again, for fear of blowing up the motor again. My suspicion is a bad lifter, I know these have hydraulic lifter and when the engine gets warm and the oil thinner, I think maybe a valve is closing or staying open because the lifter is collapsing or sticking open. Just a suspicion though. Either that or the timing chain as the chain and the lifters were the only two things not really changed. The motor sounds completely normal no ticking or scraping. Before it blew I heard piston slap and lifter tick, the slap is gone now, but the tick is only present when at operating temperature. Only code stored is for the 24x Crankshaft Position Sensor and that has been there since I've owned the car. Any help would be greatly appreciated as I've spent so much money on this thing as of now and to just have it sitting here is quite depressing. ~Thanks! |
| All times are GMT -5. The time now is 05:45 AM. |
