-   -   P0341 Code on Pont. GrandAM 2001 6Cyl 3.2L (https://www.pontiactalk.com/forum/grand-am-18/p0341-code-pont-grandam-2001-6cyl-3-2l-1495/)
Cougiaurmeh May 27, 2008 02:15 PM
My wife's car, a Pontiac Grand AM SE1 2001 6Cyl 3.2L is having a "check engine" light on every now and then, and it's interfering with our safety inspection. The engine runs fine, however. I researched the code and found out it had to do with an intermittent fault on the camshaft position sensor, and found the problem could be anything from a loose wire, to a camshaft sensor, to an element on the camshaft.
So, I think I'll get it diagnosed at a shop, and then fix it myself. Now, does anyone know any good companies that can diagnose for cheap?
I'll return to this thread when the problem is diagnosed because next I need help knowing how to fix it. I learn fast and have an affinity for mechanical stuff, just cars are a tad new to me among other things.
boydfoose Sep 27, 2010 02:32 AM
try this website http://www.obd-codes.com - I had the same problem from the past! Today's car are very digital. too much tech stuff on the dashboard.
pontiac grand am parts
