1994 SE
How difficult is it to swap an engine in a 1994 se with the 3.1 liter? Is there any place to get detailed instructions.?
Russ455 |
RE: 1994 SE
If you're looking at an exact swap with the 3.1L it's not that hard. The chilton manual does a pretty good job at it but I prefer the Haynes manual though. If your looking to upgrade I would say a 3.4 would be the same aside for maybe a bigger ring and pinion gear in your differential and maybe tweak the gear ratios. Anything bigger would prob be more indepth like bigger fuel pump, altenator.....I don't really know. Hope this helps.
| All times are GMT -5. The time now is 02:37 AM. |
