-   -   2006 GP Window problem (https://www.pontiactalk.com/forum/grand-prix-16/2006-gp-window-problem-1796/)
ShingCTse Jan 21, 2009 08:34 PM
I have a 2006 Grand Prix Gt, and I am having difficulties with the windows. The problem is that my windows will not roll up at all, but when I try to roll my driver side window down, it makes a buzzing noise. All the other windows have no response what-so-ever when I try to roll them up or down.
Any suggestions?
If you suggest that it is a fuse, where would it be located? I looked in the fuse box on the side, and couldn't locate the fuse specified for the power windows.
Thanks
112mars Jan 23, 2009 09:29 PM
RE: 2006 GP Window problem
mine also has trouble like that.one thing i can tell you is the window motors in mine burned out quick and i have had to replace 2 of them.once you are sure that is not the problem,its most likely in the switch itself.do the other window respond when you use the control on that door for the window you try to put down?if they work individually,then theres your prob.its in the driver door switch
