Maximize cooling efficiency of your Pontiac with Frostbite Products at CARiD!
Cooling system is a critical part of your ride's performance and longevity of your engine. Whether you're using your car during hot summer days, in slow-going traffic or in in extreme racing conditions, it is important to keep your engine cool. Frostbite is well-known expert in performance cooling systems and their product line is now available at CARiD! It includes a variety different units, but we would like to talk about the most important ones – the radiator and the water pump.
Radiator is the heart of your Pontiac's cooling system and this is where all the cooling magic happens. Frostbite 2 Rows Aluminum Radiator would be great for applications with 300-500 horsepower. It is engineered with aircraft-quality aluminum cores, fittings, tanks with billet aluminum filler necks, and OEM-style brass petcocks. It is up to 30 percent lighter than copper/brass OEM-style radiators and have a special aluminum core which is far more corrosion-resistant than traditional models.
Frostbite® - 2 Rows Aluminum Radiator
Water pump takes care of the proper coolant flow through your engine and radiator. It eliminates heavy cast housings, and impeller drag. Frostbite Electric Water Pump is made utilizing top-grade aluminum and available in black or polished finishes, and short- and long-style configurations. Each water pump is thoroughly inspected and tested before it leaves the factory and is rated at 35gpm flow rate. It comes as a complete kit with gaskets, wiring pigtail, and mounting hardware included.
Frostbite® - Electric Water Pump
Watch this video to find out more about Frostbite products:
Frostbite Radiators - YouTube
Find the full line of Frostbite products here:
Frostbite™ | Radiators & Performance Cooling Parts — CARiD.com
Don't let the heat ruin your engine. Keep it cool with Frostbite performance products at CARiD!
carid
Member Group And Special Buys
04-14-2015 08:51 AM
carid
01-08-2015 06:21 AM
Speed Engineering
03-05-2007 03:00 PM
